Hot Air Stenter Is one of the Many Types of Stenter
Started by stenterlicheng, Mar 09, 2020, 02:59 am
previous topic - next topic
Go Down
stenterlicheng
Hot Air stenter is one of the many types of the stenter and it is more obvious difference between the other stenters is the heating device ,it is through the hot air directly heating on the fabric , while some stenters make air as heating source ,such as air stenter .
In fact the stenter's process itself is developed on basis of extrusion molding. The fabric after the treatment of hot air stenter is obbious differences between the products that no treament and from the appearance can be distighuished .
Tests have shown that the fabric is treatment by the hot air ,the strength has been significantly improved , can be achieved without processing products 3-5 times; and the fabric surface gloss will become better, the permeability of the fabric decreases with water and air and improve the value-in-use.
Function of stenter Machine
1. Heat setting is done by the stenter for lycra fabric , synthetic and blended fabric.
2. Width of the fabric is controlled by the stenter.
3. Finishing chemical apply on fabric by the stenter.
4. Loop of the knit fabric is controlled.
5. Moisture of the fabric is controlled by the stenter.
6. Spirility controlled by the stenter.
7. GSM of the fabric is controlled by stenter.
8. Fabric is dried by the stentering processs
9. Shrinkage property of the fabric is controlled.
10. Curing treatment for resin, water repellent fabric is done by the stenter.
More information about Hot Air Stenter Is one of the Many Types of Stenter, please contact Stenter Machine and Flat Screen Printing Machine manufacturer - LiCheng or click https://www.hotairstenter.com/
vugor
инфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфо
инфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинйоинфоинфоинфоинфоинфо
инфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоtuchkasинфоинфо
Go Up
