Release Notes - integration 1 Aug 2017
Started by Artur, Aug 10, 2017, 08:35 am
previous topic - next topic
Go Down
Artur
Aug 10, 2017, 08:35 am Last Edit: Aug 10, 2017, 11:48 am by Artur Reason: adding info
eZLO Smart Home Automation company proud to announce new Release !
New Z-wave devices now became compatible with eZLO Smart Home Hub:
You can see full list of integrated devices till August,1 in attached file below.
1 Philio Siren PSE02-2B
2 Aeon Labs Dimmer DSC08101-ZWUS
3 Everspring Plug AN163-1
4 JASCO Plug ZW3101
5 Hank Plug HKZW-SO03
6 Everspring Motion sensor SP103
7 Everspring Smoke sensor SF813-2
8 GoControl Switch FS20Z-1
9 Linear Switch WO15Z-1
10 Linear Switch WT00Z
11 GoControl Dimmer WD500Z-1
12 GoControl Plug PS15Z-2
13 Fortrez Water sensor WWA01AA
14 Fortrez Water sensor WWA02AA
15 Everspring Motion sensor HSP02-0
16 Hank Door\window sensor HKZW-DWS01
17 Linear Door\window sensor WADWAZ-1
18 Aeon Labs Switch DSC24-ZWUS
19 Aeon Labs Dimmer DSC25-ZWUS
20 Remotec Thermostat ZTS-500US
21 Philio Motion sensor PST02-A
22 Aeon Labs Scene controller DSA38-ZWUS
23 Remotec Plug ZDS-200NA
24 Everspring Lamp Socket AN145-1
25 Honeywell Thermostat YTH8320ZW1007
26 Aeon Labs Switch ZW078-A
27 Aeon Labs Extender/Repeater/Transceiver DSD37-ZWUS
28 Hank Scene controller HKZW-SCN01
29 Hank Scene controller HKZW-SCN04
30 Aeon Labs Door\window sensor ZW120-A
31 Fortrez Siren SSA2
32 JASCO In-Wall Outlet ZW1001
33 GoControl Bulb LBR30Z-1
34 Remotec Extender/Repeater/Transceiver ZXT-120US
35 Ecolink Door\window sensor DW-ZWAVE2.5-ECO
36 Aeon Labs Door\window sensor ZW112-A
37 Linear Door\window sensor GB00Z-1
38 Utilitech Water sensor TST01-1
39 Everspring Illumination sensor ST815-2
40 Aeon Labs Scene controller DSA03202W-ZWUS
41 Aeon Labs Bulb ZW098-A52
42 Hank Bulb HKZW-RGB01
43 Vision Door\window sensor ZD2201US-5
44 GoControl Siren WA105DBZ-1
45 Hank Switch HKZW-SW01
46 Hank Extender/Repeater/Transceiver HKZW-ACC01
47 Vision Curtain control ZW4111US-5
48 Aeon Labs Energy meter DSB09104-ZWUS
49 Aeon Labs Energy meter DSB28-ZWUS
50 Fortrez Water & Irrigation WV-01-050
51 GoControl Scene controller WA00Z-1
52 HEIMAN Gas sensor HS1CG-Z
53 HEIMAN Motion sensor HS1MS-Z
54 HEIMAN Plug HS2SK-Z
55 HEIMAN Water sensor HS1WL-Z
56 HEIMAN Door\window sensor HS1DS-Z
57 GoControl Dimmer LB65R6Z-1
58 HEIMAN Temperature and Humidity HS1HT-Z
59 Aeon Labs Door\window sensor DSB04100-ZWUS
60 Aeon Labs Dimmer DSC19103-ZWUS
61 Aeon Labs Switch DSC18103-ZWUS
62 Aeon Labs Siren ZW080-A17
63 Aeon Labs Motion sensor DSB05-ZWUS
64 Ecolink Motion sensor PIRZWAVE2
65 Everspring Door\window sensor HSM02-0
66 Aeon Labs Switch ZW096-A02
67 Aeon Labs Power-Strip DSC11-ZWUS
68 Aeon Labs Water sensor DSB45-ZWUS
69 MCO Home Switch MH-S511H-us
70 Aeon Labs Switch DSC26103-ZWUS
71 MCO Home Switch MH-S212-US
72 Aeon Labs Switch DSC06106-ZWUS
73 Linear Dimmer WD1000Z
74 Hank Plug HKZW-SO01
New Z-wave Command Classes integrated to eZLO ecosystem,
so more devices will be compatible in future!
загрузить картинку
Evesaraporn
After reading this content It made me learn more about this subject.
Go Up
