Follow The Steps Of 123.hp.com/setup To Setup HP Printer
Started by dany41, Dec 03, 2020, 03:14 pm
previous topic - next topic
Go Down
dany41
When setting up the printer for the first time, these are the steps you will need to follow. First, you will need to unpack the HP DeskJet 3630 from the box. Setup printer through 123.hp.com/dj3630. When you take the printer out of the box, materials like tapes and stickers should come off. The ink cartridges must be installed. Then you will need to load the paper into the input tray. After this, install the printer software.
Go Up
